| Version(s): | 10.06.00.38+ |
| Area: | Corridor Modeling |
| Original Author: | Chris Key, Bentley Technical Support Group |
This video demonstrates the new ability to create a fillet transition for a point/corner within a component. The fillet is defined by a tangent length along the component edge. The fillet can be applied and adjusted for any point along a component.
