Creating an Inspection
  1. Creating an Inspectioncan be done in SYNCHRO Field App from the Project Home Page by selecting Inspection in the Create Tab.
  2. When creating a New Inspection any field with a Red Asterisk (*) are mandatory and need to be populated in order to save the Inspection.
  3. Inspection name is a free text field to assign a subject heading to the Inspection.
  4. Pay item allows users to select a pay item for construction objects of a certain category.
  5. Form Category is pre-populated drop-down menu that allows the user to categorize the Inspection form.
  6. Form is pre-populated drop-down menu that allows the user to pick the Type of Inspection form.
  7. Select the Inspect button once all the mandatory fields are completed.
  8. After you click Inspect, you will enter the inspection form where you can edit/view more details of your inspection.
  9. Towards the bottom of the inspection form you will have the option to add Attachments.
  10. Users can add a Map Location which allocates the user to geographically pinpoint the location of the Inspection in the Map. Select the check mark once you have the inspection icon on the required location.
    Note:    option will locate your location on the map for reference.
