Listen to an Audio Note [Web & Mobile]
- Any note that was recorded by voice within the SYNCHRO Notes app will be available for you to listen to at all times in the Daily Log web portal (even after the audio has been transcribed).
- Any note with a voice file will display a play button when you hover over the note.
- Click on the play button to listen to the audio file for the note.
- Log into the SYNCHRO Notes app for Apple iOS or Android devices.
- Select the project you wish to enter.
- Find the note you wish to listen to.
- Tap on note menu icon (displayed as three dots "•••").
- Tap on "Play Audio."
