Log into SYNCHRO Daily Log web portal
Navigate to the project you wish to export all the images for.
Click on the magnifying glass displayed to the right of the Daily Report.
Search for the date range that you'd like the images for. If you wan all images for the entire duration of the project, select the 'All Time' date range option.
Once the results display, click on the blue 'Export All' button on the search results.
A confirmation will appear. Click on 'download all images.'
Note: If the file is too large, the zip file of images will be emailed to you. In addition, make sure you don't have your pop-up blocker enabled or else you won't be able to download files
