Delete a Note [Web & Mobile]
- Hover over the note you wish to delete, and click on the note menu (displayed as ☰) on the top right of the note.
- Click on "Delete."
- Log into the SYNCHRO Notes app on either your Apple iOS or Android device.
- Select the project you wish to enter into.
- Find the note you wish to delete.
- Touch the note and swipe your finger from the right to the left.
- A delete button will appear, tap on it.
