By default, the name of the Daily Report is 'Daily Report,' but you can change this by following these steps:
- Select the project you wish to change the Daily Report name for from the project list dropdown menu.
- Hover over the Daily Report title (you will see a little 'v' symbol appear).
- Click on the 'v' symbol, and the 'EDIT REPORT NAME' module will appear.
- Rename the Report Name to whatever you wish.
- Click 'Save.'
