Add a Weather Entry
Projects have Auto-Weather enabled by default, which provides a weather entry 3 or 6 times per day.
To manually add a Weather entry:
  1. Log into the SYNCHRO Daily Log web portal
  2. Find the desired project by clicking on the project selector dropdown menu at the top of the page.
  3. Click the ‘ADD’ symbol (displayed as +) at the top of the vertical toolbar.
  4. Click on ‘Weather’.
  5. Input the information (temperature is a mandatory field) and click ‘Save’.
