Enable/Disable Project Notifications
You can enable and disable Notifications you receive for each project in your project preferences.
  1. Log into the SYNCHRO Daily Log web portal
  2. Click on “USER SETTINGS” (displayed as ) at the top left-hand side of the page.
  3. From the new User Settings page, click on “Project Preferences”.
  4. Once in "Project Preferences," check/uncheck the boxes for the row that corresponds to the project you wish to alter your Notification settings for and the column of the Notification you wish to alter.
  5. A checked box enables the notification, an unchecked box disables the notification.
  6. Scroll down and click "Save."
