Log into the SYNCHRO Daily Log web portal
Hover over the Note you wish to tag to an issue.
Click on the Note menu icon displayed as ☰ in the top right corner of the Note.
Within the Note menu, click on 'Issues.'
You can either:
Select an Issue from the drop-down menu to tag the Note to, or
Click on 'Create a New Issue' to add another item to the drop-down menu
