Locations only appear for Notes taken in the SYNCHRO Notes app for Apple iOS and Android devices.
Once logged into the SYNCHRO Daily Log web portal, a location pin icon will appear over notes that have locations available.
You must hover over the note in order for the location pin icon to appear.
Click on the location pin icon and the location will open up on a Google Map.
Log into the SYNCHRO Notes app.
Select the project you wish to enter.
Find the Note you wish to see the location for (remember, you can only see the location for notes taken in the SYCHRO Notes app).
Tap on note menu icon (displayed as three dots "•••").
Tap on "View Location."
