Project Administrators can disable project users at any time
Log into SYNCHRO Daily Log web portal
Click on "Account Settings" at the top right hand side of the page.
Click "Account Users" which will display a list of active users.
Uncheck the box in the Enable column to disable the user.
This will remove the user's access and prevent them from logging in to SYNCHRO Daily Log, Notes and Crew.
