Only Project Administrators can change a user's access. User access is managed on a project basis, so when adding a user to a project, you select the required Access Level .
After logging into the SYNCHRO Daily Log web portal, find the desired project by clicking on the project selector drop-down menu at the top of the page
.Click on ‘PROJECT USERS’ on the vertical toolbar towards the right of the page.
Click on the drop-down menu next to the user's name and select the new Access Level. Refer to Project Access Levels for details.
Once completed, scroll to the very bottom and click on the blue "Save" button.
You can also amend the users Notifications such as adding them as a receiver of the Daily PDF Reports.
