Input a Labor Entry [iOS/Apple]
After logging into SYNCHRO Crew and selecting the appropriate project, you will notice a plus sign button (displayed as +) on the top right-hand corner of the screen.
You will be prompted to enter a short description of work that is being performed.
For example, if the labor being recorded are for the concrete being completed, your short description could be "concrete forming."
