Locate the note in which a Category needs to be tagged to.
Once found, select Add Category underneath the note.
A list will populate with all Categories for the project, then tap the box to the right of each Category in order to add.
After all appropriate Categories are enabled, tap the back button on the Android screen and you'll notice a number located next to Category(ies) for the amount that was tagged.
