Comment on a Note [Android]
  1. Locate the Note in which a Comment needs to be inserted.
  2. Once found, select Comment underneath the note. The keyboard will display and you may begin typing.
  3. After typing the necessary text, tap Add to the right of the Comment.
  4. After you are finished commenting, tap the back button on your Android device, then underneath that Note 1 Comment will show.
  5. You can view the comment by tapping 1 Comment underneath that Note.
