Log into the SYNCHRO Notes app.
Select the project you wish to enter.
Find the Note you wish to comment on.
Tap on the "Comments" button (located on the bottom of the note).
Type your comment.
Click the "Add" button when you are done.
After you are finished commenting, hit the back button in the top left hand corner, then underneath that note 1 Comment will show.
You can view the comment by tapping 1 Comment underneath that Note.
