Edit the text of a Note [iOS]
  1. Locate the Note in which you need to make edits to.
  2. Once found, tap on the text that was previously recorded and you will be brought back to a text editor screen.
  3. Add or remove any information you choose then tap Save in the top right hand corner.
  4. You will return to the dashboard and see the edit was applied.
