Use SYNCHRO Notes Transcription Without a Smartphone
To use the transcription without a smartphone, you will need to set up a project phone number. You will need to be an account administrator.
  1. Log into the SYNCHRO Daily Log web portal.
  2. Go to your 'ACCOUNT SETTINGS' (displayed as a gear icon on the top right).
  3. Click on 'Account Projects.'
  4. Click on 'Add Project.'
  5. Fill in project details.
  6. Select 'Yes' for the question regarding users not having access to a smartphone (this is essential, otherwise a phone number for the project will not be created).
  7. Click 'Save' when you are done.
  8. You will now see a project phone number below the project name.
Users can call that phone number to input voice notes into the project. The transcription team will then transcribe their voice notes into words (unless you have transcription turned off for your account).
We recommend storing the project phone number and project email address. You can email in photos and files that you would like to add into the daily report as well.
Note: The Voice Transcription Service is a paid service.
