Version 3.0.9 onwards, we have enabled settings to allow you to save a copy of the photos you take while using SYNCHRO Notes on your device. The new photos will be saved in Photo Gallery in an album named SYNCHRO Notes. This allows you to save photos in your device's gallery so you have access to them outside of SYNCHRO Notes. This is a configurable setting, to enable this feature follow these steps. settings to opt in for that option.
Open the settings on your IOS device and browse to the SYNCHRO Notes application settings
The photos you take now from within SYNCHRO Notes will be saved in your devices Photo Gallery.
