Locate the Google Play Store on your Android smartphone home screen.
Find the search bar at the top of the phone,
Type in SYNCHRO then click the magnify glass on the bottom right hand side of the keyboard
Select SYNCHRO Notes or SYNCHRO Crew then choose Install.
Refer to Minimum Android Device Requirements for SYNCHRO Notes or Crew for minimum device requirements
