News Feed
The News Feed displays all notes posted to all projects that you are on by all users. Your SYNCHRO Notes account may have many projects, so the News Feed will only display Notes for projects that you are on.
In addition, your project access level may change what you see in the News Feed. Refer to Access levels for details
To access the New Feed:
  1. Log into the SYNCHRO Dail Log web portal
  2. From the landing page, select the dropdown arrow
  3. Select New Feed
