Launching the Model
Once a model has been linked in SYNCHRO Control user will have access to the Model within the SYNCHRO Field app.
- From the More page click on the Models Icon at in the options.
- If this is the first time opening the Model in SYNCHRO Field, you will be required to Download the Model you want to access. If the Model is already downloaded and changes have been made in SYNCHRO 4D Pro you will be required to Update the Model.
- To remove a model, select the 3 dots on the bottom right corner of the iModel container, then select the Remove from this device.
Main Screen Options
From the main Model screen there are different options on setting up the view of the model.
- The Play back bar activates the construction schedule animation sequence. Users can turn the Playback bar on or off by selecting the clock icon on the top bar.
- User can change the view option by selectin the 3 Dots on the top bar. Fit View will center and fit the whole model in the screen. Change render mode will give the option of different render to view the model.
- Users have the option of viewing the model in Smooth, Hidden line, Solid fill, or Wireframe.
- Once objects on the model are selected, users have the option to view the Properties, Hide, Isolate, Emphasize or Deselect.
- Users can switch from Previous or Next view by using the icon on the top bar.
Create
Create is a quick link to tag the model to a form.
- Choose the Form you want tagged to the model, then select the element in the model you want the form tagged to. Once you have the Icon placed on the required element, select the green Create arrow on the bottom right corner of the screen.
- This will open up the form to add all the required info.
Views
Views gives the users the option to switch between saved views within the model.
