Create provides shortcuts to allow quick access to the Issue, Observation, Daily log, Inspection and RFI.
- Issue– to log and manage issues that arise in the project and prioritization of resolution.
- Site Observation – to record/flag specifics at the site i.e. truck is blocking the way, rebar doesn't have rebar caps.
- Daily Log – to record information, incident, progress from each day at the job site.
- Inspection - allows users to create and submit inspections for the construction project.
- RFI – to log and manage Request for Information in the construction project.
- Work Package – allows users to create work packages in the field. Adding pictures, video, and document information for the work package while in the field.
