Download All Notes for a Project
  1. Log into the SYNCHRO Daily Log web portal.
  2. Select the project you wish to enter from the Switch menu.
  3. To the right of the daily report, you will see an arrow pointing up diagonally.
  4. Click the arrow icon to Export.
  5. Choose PDF or Spreadsheet, and a date range.
  6. Click the blue Export button. You will receive an email with the exported data attached.
Download All Notes for the Account (CSV only)
Please note: This can only be done by Account Administrators.
  2. Click the Account Settings gear in the upper right corner.
  3. Click the blue Show Export Option button.
  4. Select the date range and type of data you need to export.
  5. Click the blue Export button. You will receive an email with the exported data attached.
