Add a Note [Web]
Notes can be added to the SYNCHRO Daily Log web portal
  1. Log into SYNCHRO Daily Log web portal.
  2. Enter into the project you would like to add a note to.
  3. Click on the "ADD" (appears as a plus sign "+") to the right of the daily report.
  4. Click on "Note / Photo / Video / Attachment."
  5. Type your note and tag it to a category and/or issue if you wish.
  6. Add a photo by clicking on "Choose File."
  7. When you are done, click the blue "Add" button to save and add the note.
You can also add a Note through the SYNCHRO Notes smartphone app, available for iOS and Android.
Refer to Add Note iOS or Add Note - Android
