SYNCHRO Field Android 3.2.20 (December 18th, 2021)
- Added new Plan Set sheet navigation feature.
- Added upload documents feature.
- Form permission improvements.
- Major bug fixes and stability improvements.
SYNCHRO Field iOS 3.2.20 (November 20th, 2021)
- Major bug fixes and stability improvements for models
- Fixed issues related to iOS 15 and performance increase for forms
Plan Set Sheet Navigation
Now users have arrows to easily flip through your plan set sheets in the mobile application.
- In SYNCHRO Field, open your construction project and access 'Documents'
- Navigate to your PDF plan set, open a document
- In the upper right-hand corner of the document, two arrows now appear: toggle back and forth between your PDFs
