Plan Set provides the latest revision of the documentation set to office and field. Users can upload pdfs and manage them as individual sheets with title block information for searching, and each revision of the sheet is managed as a separate subject.
- Expand: To view all the individual revisions in sequence.
- View Options: Toggle in between Table View or Map View.
- Download: To download the sheet.
- File Info: Displays general information of the sheet, including File name, Discipline, Revision, Revision date, Revision description, etc.
- Open single sheet: Opens an editor that allows you to edit the sheet.
- Open on map: Opens the sheet in Map View.
- Edit details: Opens the PDF Settings page where the details of the sheet can be edited. We will learn PDF Settings in a later chapter.
