Standard Layout
Standard Layout is the default layout that automatically arranges the PDF printout based off the order of the Design Form page layout.
Standard Layout Setup
Export to PDF
When exporting a Standard layout form to PDF users will get the option to include:
Note: When selecting the Export attachments option, a zipped file will be downloaded to the users Downloads directory. The zipped file will include a PDF copy of the Form and a folder containing all images and attachments.
