PDF Settings lets you create a Plan Set in a Bentley Infrastructure Cloud project. The First document issued to Field will have revision 0 with a completed sheet. If a revision is submitted on certain sheets only those sheets will be issued to Field, not the whole set document. It is a challenge to ensure the team in the field is using the latest revision. The PDF settings feature helps provide the team in the Field with the latest revision.
