Restricted Access is a simple, yet effective form permission control that allows users to fill out a form instance and restrict access to it. This will enable basic submittal management where multiple, unrelated subs could be submitting the same form without seeing each other’s work. Restricted forms are only visible to the creator, primary assignee (Assigned to field) and secondary assignees (Multi assign field).
At the bottom of all forms, there is a button that allows the creator or the reviewer to restrict access to creator and assignees. By checking the box, these form instances will only be visible to the creator as well as any user that the form instance has been specifically shared with and/or assigned to. For the user(s) that have visibility to these form instances, they will display to them in their list of forms just like any other form instance. For those users without access, these forms will not be visible.
Previously, the option to restrict access to a form was displayed at the bottom of every form in SYNCHRO Control but was defined in the forms designer.
Now this option needs to be added as a checkbox control in the form designer for it to display on your forms. This allows the project administrator(s) to determine whether to display the option or not on a per form basis.
Important: Any Form definition that does not have this option defined in the forms designer by will no longer see it on your older forms which do not have it defined in the form definition.
Who can see the form instance if Restrict access to creator and assignees is selected?
Who sees the form instance if my form does not have the multi assign component enabled?
What can users without access to a form instance see?
By default, the grid hides all form instances to which the user does not have access. Under the filters, the user can show restricted form instances, which shows limited information about each instance:
Note: This can be helpful in case administrators need to track down form instances to which they believe they should have access, while at the same time it does not reveal any sensitive information. When a user enables Show restricted forms, all restricted information will show as [Hidden] in the grid.
Does this override form permissions set for the project?
Restricting access to a form instance will further restrict access but will not grant additional permissions that are not allowed as per the project settings.
During a re-assignment, will the previously assigned user/role lose access?
Yes, if a user/role was assigned and a re-assignment is needed, they should be added to the secondary assignee list using the multi-assign component. If a user/role is removed as the primary assignee and is not added to the secondary assignee, they will lose access to the form instance.
Note: This also applies to any automated re-assignment that has been configured in the workflow settings for the form definition.
If the box is unchecked, what happens with the permission?
Once the Restrict access to creator and assignees is unchecked, the form instance permissions go back to being controlled by the project-level permissions. That means that any user with the permission to view forms of that definition will see the form instance, regardless of whether they are listed as the primary or secondary assignees.
