The following columns are provided to define information about the selected form:
| Form definition | Form definition name |
| Prefix | The prefix to generate a unique number |
| Type | Form type |
| Status | Form status (Published, Draft or Archived) |
| Workflow | Workflow status (Enabled or Disabled) |
| Filled out | The number of how many form instances have been created. |
| Published | Form is in production stage and available in SYNCHRO Control/Field. |
| Draft |
Form is in design mode. Not available in SYNCHRO Control / Field. Form definition can only be edited while in a draft status. |
| Archived | Form is not available for new instance, only can view existing instance. |
