Each form can have its own unique role-based permissions.
- Go to the Manage Forms page in the Administration Then select the Form Definition of the required form.
- Any form that required the Permissions to be set will have a warning icon beside the prefix.
Note: Permission must be set before the form can be published.
- Once the Form definition has been selected, choose Set permissions from the top banner.
- Each Role can be assigned Permissions by checking off the required Permission checkbox. Once complete select Save.
