A document set is a group of documents that have been manually added to a container (the set), usually for some purpose, such as to simplify the downloading of multiple documents that exist in different folders. For example, when you download the set, all documents in the set get downloaded.
When you click the action menu next to a document set, you will see all of the options available to you for working with the set. When you have a document set open, you can click the action menu for any document in the set and perform actions on them just as you would from the document's parent folder.
A set can contain one or more documents, and the documents in a set can exist in different folders. A document can be added to as many sets as you want.
Creating a document set
To create a new document set and then add documents to it:
The documents are added to the set.
To create a new document set from pre-selected documents:
Note: If you close an empty document set before adding documents to it, the set will not be saved to ProjectWise. Once the last document is removed from a document set, the empty set is automatically deleted.
Opening a document set
You open a document set in ProjectWise Web with a single click, just like you are opening a folder. The document list displays a list of documents contained in the set.
Locking the version of a document used in the document set
The Lock to version setting determines which version of a document will be included in the set.
To use this feature:
When you add the active version of a document to the set and turn this setting ON for that document, then the set becomes locked to the specific version of the document that you added to the set (it locks to the sequence number of the version), so that as new versions of the document are created, the set will always use a specific version of the document (the version that was the active version when the setting was turned on).
When you add the active version of a document to the set and turn this setting OFF for that document, then the set will always include the active version of that document, even as new versions of the document are created.
Note: Whether the setting is on or off by default after you add a document to the set depends on whether the datasource setting Versions > Lock flat set documents to versions has been turned on or off by your administrator (this is configured in ProjectWise Administrator).
Adding and removing documents to a document set
Once a set has been created, you can add more documents to it or remove documents from it as needed.
