Roles
Note: Refer to this wiki for additional information on Guest User Access.
You can customize the project Roles to control who has access to what data in SYNCHRO 4D, Control, and Field. Select Administration > Manage your team, then select the Roles tab.
Steps to create a new Role
  1. Click Add role.
  2.  Enter the Role name and Role description (example: Site Representation). You may choose to Copy permissions from existing roles as a starting point to create a similar role.
    Permissions are broken down into different headings that can be expanded to select the required permissions.
    Each permission has an information icon beside it giving more details of what the permission does. Eg. -
  3. Some permission will have the option to Select all and Clear all to quickly select or remove all the checkboxes.
    Some suggested roles and corresponding permissions are below:
  4. Once all the required permissions have been chosen, click Save.
  5. In the Assigned To column, the number of users assigned to the role is displayed as a link:
    Click on the link to display the list of users assigned to the role:
  6. From this dialog, you can remove users individually, or remove all users if desired.
SYNCHRO 4D Permissions
The relevant permissions related to SYNCHRO 4D are as follows -
Notes:
