Import a Workflow Template
Delete a Workflow
Adding Statuses
Adding Transitions
- When there is no workflow assigned to the form, the Import Workflow Template button will be visible.
- Click the Import Workflow Template button to display the following dialog providing three template workflows: (Basic, Assignment, and Review). Select a workflow template that closest suits the Forms requirement. The workflow can be adjusted to better reflect the Forms required statuses and transitions.
Workflow Template Types
- Basic Workflow: A very simple workflow that contains two statuses: Open and Closed.
- Assignment Workflow: Normally used if the form needs an assignment process.
- Review Workflow: This workflow is for a form that only needs a review process.
- The workflow is made up of three main parts:
- Status identifies the progress that has been achieved in the workflow. It distinguishes how much has been done, and what still is left to complete.
- State is used for dividing workflows into smaller stages such as Draft, Open and Closed.
- Transitions identifies when the workflow has moved from one Status to the another. Movement between Statuses cannot exist without Transitions
- When creating a workflow, users can preview at any time to ensure the Flowchart is being properly constructed. To do this click the View Flowchart button.
Note: The blue boxes are the Statuses, and arrows with the light grey boxes are the Transitions.
- New feature to export the workflow to Excel and PDF is added.
by export to excel, we can check quickly and more easily the workflow setting.
Delete a Workflow
- Delete the existing workflow by clicking the Delete Workflow
button.
- When prompted to confirm, click Yes to delete the workflow.
Adding Statuses
- To add new status, click the Add Status button.
- From here the Status Name, Starting Status and Status can be defined.
- Name: Status Name that can be customized.
- Use as Starting Status: Set if this is the starting status of the workflow.
Note: A green circle with a checkmark will identify which status is the starting status.
- State: What state (Draft, Open, or Closed) is required when the form is in this status.
- Under Actions there are options to Copy or Delete statuses.
Note: Status cannot be deleted if it is the only Starting Status in the Workflow.
- Repeat this Add Status steps until all the required statuses have been created.
- The order of Statuses can be rearranged by clicking and dragging them into the proper order.
- When the Flow Chart is viewed it’s easy to see there are missing transitions between Statuses.
Adding Transitions
- To create a new Transition, click the Add Transition
button.
- From here the Name and Status Transition can be defined.
- Name: Transition Name that can be customized.
- Status Transition: Defines the movement from one status to another.
Note: Transitions can move forward or backwards in the workflow.
- Repeat these Add Transition steps until all the required Transitions have been created.
- The Top Transition will be the default transition on the published form. The order of the Transitions can be rearranged by clicking and dragging them into the proper order.
- When the Flow Chart is viewed it’s easy to verify the Workflow structure has been built correctly.
