To access the Documents files and folders, user will login to SYNCHRO Control and select a project. From the project homepage, select Documents. The system will automatically start the authentication process to verify user login information to gain access to the document module. User will expect see the cloud connection  icon to show up and will disappear when the user is granted access to the document service.
The Documents module gives access to the following:
