Each document has an icon that indicates which application is associated with it, based on the extension of the file that is attached to the document.
Some documents will also have a smaller icon, either in the upper left or lower right corner (or both) of the document icon, which indicates additional information about the document, such as whether the document is a master document, or is a non-active version.
| Icon | Description |
| A regular folder | |
| A special type of folder called a work area | |
| A work area that is associated to a ProjectWise project | |
This can be:
| A flat document set | |
| A MicroStation DGN file | |
| An AutoCAD DWG file | |
| A Revit RVT file | |
| A Microsoft Word DOC or DOCX file | |
| A Microsoft Excel XLS or XLSX file | |
| A Microsoft Outlook MSG file | |
| An Adobe PDF file | |
| An image file (for example, JPG, TIF, PNG) | |
| A MicroStation DGN file with references (master document of a logical set) | |
| An AutoCAD DWG file with references (master document of a logical set) | |
| A document which has a more recent version. | |
| Document has been checked out to the user. Others will see a lock icon. | |
| A document whose status has been set to Final. In this example, it is a MicroStation document whose status is Final. |
