Forms vs Inspections
 FormsInspections
Create a new FormUsing blank canvas in Forms Designer;
Can only be done one Form at a time
Using the Inspection Excel configuration worksheet
Create multiple Form DefinitionsCreate one at a time;
Can copy existing Form
Create in bulk using the configuration worksheet
Edit Form definitionUsing Forms Manager
Creates multiple sections as a base design;
Can be edited with Forms Manager
Transition Workflows
Yes;
Is consistent across Form Types
Yes;
Is consistent across Form Categories
(Inspection Types)
Design PrintoutYesYes
Generates tree hierarchyNoYes
Copy definitions across projects
(Project provisioned from organization template)
Yes
Yes;
only one-time initial re-provisioning
Update definitions across projects
(Project Re-provisioning)
YesNo
Create Form instances in batchNoYes
Create Form through iModel*YesNo
Escalate a Form*Yes;
cannot escalate to Inspections
Yes
Relate a Form*Yes;
Can relate both Forms and Inspections
Yes;
PermissionsYes;
Can be set for individual Forms
Can only be set for all Inspections
DashboardYesYes
APIYesYes
*See Feature Availability by Device below
 FormInspection
 ControliOSAndroidControliOSAndroid
Create Form through iModelVXXXXX
Escalate a FormVVXXXX
Relate a FormVX*XXX*X
*Can only view related forms.
