When using 3DS Max Design with FBX animation files from Synchro, the following set-up must be performed only once to get the correct effect. Note that this is only necessary for 3DS Max Design, not 3DS Max.
1. In 3DS Max Design, select Customize>Custom UI and Defaults Switcher
2. Set Initial settings for tool options to Max. The setting for UI schemes does not matter
3. Select Set and proceed as normal.
