Is there a way to automatically subdivide 3D Objects based on Grids or Levels?
There is no automatic way of subdividing objects based on grids or level in SYNCHRO Pro. While subdividing objects, you can select the gridlines or other 3D Objects for visually referencing the cuts. Recommended practice is to do such divisions within the original modeling software.
