How can I see Cost performance Index (CPI) as a column in the Task list?
It's not possible to directly display CPI as column in the Task list, however, you can create a new User Field with the following formula to get the same information -
PROPERTY("Earned Value Cost [BCWP]") / STRING_PROPERTY("Actual Cost [ACWP]")
