Can we set Appearance Profiles within SYNCHRO Pro, that were defined in P6?
You can write Appearance Profiles names in a Customed Defined Field, within P6. This will import over to SYNCHRO Pro as a User Field, which can in turn be assigned as the actual Appearance Profiles using the following Script -
TASK.ASSIGNMENT SET_PROPERTY ( PROPERTY("Appearance Profile"), ALL_USE_PROFILE( NAME == TASK.UFV("P6 Profile")))
