Why do I keep getting errors or a blank progress bar on exporting to Microsoft Excel?
If you are getting any errors export to Excel, add x64-bit ODBC support by installing the Microsoft Access Database Engine 2010 Redistributable.
Alternatively, use the Copy Task (right-click > copy) to copy schedule information from SYNCHRO to paste into MS-Excel; or Paste Task as Text features to paste information copied from MS-Excel into SYNCHRO Pro.
