Why can't I see material textures on my model when exporting from Revit using the SYNCHRO Plugin?
SYNCHRO plugin exports an SPX format file that does not support material textures. However, exporting the Revit model as an DWFx will enable you to see the textures within SYNCHRO Pro.
