Why can’t I see the 2D Text when importing an SPX generated from Navisworks using Synchro Plugin?
SPX format does not support 2D Text and will not be exported using the Plugin. The recommended process is to export an DWFx format from the original CAD/BIM software for all 2D lines and text. Also make sure to enable visibility for both these options in SYNCHRO Pro -
