SYNCHRO Pro - DWG import with Error "Resource Manager is not correctly installed"
"Resource Manager is not correctly installed" error when importing DWG
After upgrade to 6.2, when user imports DWG into SYNCHRO Pro an error message may occur: "Unable to locate resource string, Resource Manager is not correctly installed."
