Plugins
- ProjectWise: ability to change datasource on SynchroniseTo
- ProjectWise: use document GUIDs for synchronization
- Added plugin support for Revit 2021
- Added plugin support for Navisworks 2021 and Navisworks Simulate 2021
No, you need SYNCHRO plugin to successfully export and keep updated models synchronized with SYNCHRO Pro. However, the plugin is only compatible with Navisworks Manage.
