10.03.02.39 July 2021
- Named version can't be selected in Design Change Management when Named version changes calculation is in progress. There is no progress indicator of Named version changes calculation and page is not refreshed. Reopen Design Change Management after some time to select Named version.
- Some properties are not listed in Property drop down in Assign by query
- Volume is not calculated for not closed shapes elements
- Reality Data doesn't work correctly when split view is ON
- Visibility eye is not displayed for some nodes (related with a large number of items in tree)
- Some properties doesn't support US Survey unit system
- Split parts appears in other location after slicing
- Some quantities for previous assignments aren't calculate
