Visibility Tree
The widget provides options to select and toggle the visibility of the following entities within the iModel -
The following visibility toggles are available -
  Show All shows all the elements.
  Hide All hides all the elements.
  Invert inverts the current selection.
  Toggle 2D Views only shows or hides all 2D elements.
  Toggle 3D Views only shows or hides all the 3D elements.
  Open the search bar to filter through elements in the active visibility tree.
Model Tree
Displays the model hierarchy of all 2D/3D elements, that is generated based on the model format and the iTwin Connector used.
Video -
communities.bentley.com/.../Model-tree.mp4
Categories
Displays the list of Categories that all 2D/3D element belongs to, that is generated based on the model format and the iTwin Connector used.
Spatial Containment
This feature is currently not supported.
Reality Data
Displays all the Reality data associated with the iModel through SYNCHRO Control, including the Bing mapping service and Reality Mesh through ContextCapture.
Video -
communities.bentley.com/.../Maps.mp4 communities.bentley.com/.../Reality-data_2D00_4.mp4
