To run SYNCHRO Modeler, you need these minimum hardware specifications.
| Processor | Intel® or AMD® 64 bit processor 1.0 GHz or greater. |
| Memory | 2 GB |
| Video | Intel HD Graphics 520 |
| Graphics API | Direct 3D version 11 or laterOpenGL |
| Screen Resolution | 1024 x 768 or higher. |
While the minimum requirements allow you to run the product, the recommended requirements provide you with better performance with a higher frame rate and allow you to view larger models.
| Processor | Intel® or AMD® 64 bit processor 2.8 GHz or greater. |
| Memory | 8 GB or more. More memory almost always improves performance, particularly when working with larger models. |
| Video | Dedicated graphics card with minimum of 2 GB VRAM or more. |
